aussiebob Posted August 18, 2024 Share Posted August 18, 2024 Spoiler Link to comment Share on other sites More sharing options...
gogmorgo Posted August 18, 2024 Share Posted August 18, 2024 Excessively high idle is usually due to air getting into the engine some other way than through the throttle. Vacuum leak, bad intake gaskets, etc. There’s also other factors that could cause it. A stuck open Idle Air Control (IAC) valve could cause a mild high idle. A throttle stuck open, either of it’s own accord or due to a sticky cable or a floor mat jamming the gas pedal can also cause a high idle. Link to comment Share on other sites More sharing options...
aussiebob Posted August 27, 2024 Author Share Posted August 27, 2024 Thanks gogmorgo back manifold bolts where loose ,back to normal. Kudos Mate. Link to comment Share on other sites More sharing options...
