Need Help Please
Having problems with my high beams. If anyone knows how to fix this I would like any info you can give. When I turn my high beams on I have a hard time turning them off again, usually not in time for a passing vehicle. It usually takes a long time of me holding the switch for them to turn off. if it is the switch does anybody know how to change it.
I'd never had hi-beams on the 88 until one day I read about someone else having difficulty with theirs and it was pointed out that the lever you pull on the column is connected by a long bar to a switch located at the base of the column. In my truck that bar had become dislodged from its proper location and I had to loosen the switch and realign the parts. Took a minute to figure out how but it was pretty simple and now I have hi-beams. :D
