jeff351 Posted May 25, 2024 Share Posted May 25, 2024 Doing my 97+ conversion, the drivers door bolted right up pretty much spot on. The passengers door was way off however - for the lower hinge I had to use a couple of thick washers under each bolt plus the factory shim to get the door to line up. The top hinge 'only' uses 1 washer with the shim. Does anyone make thicker shims? These washers are only temporary. Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 25, 2024 Share Posted May 25, 2024 It looks like you are missing the cupped spacer. Link to comment Share on other sites More sharing options...
jeff351 Posted May 25, 2024 Author Share Posted May 25, 2024 3 hours ago, pizzaman09 said: It looks like you are missing the cupped spacer. ahhh...you are correct! Long gone. Link to comment Share on other sites More sharing options...
TCB89MJ Posted May 26, 2024 Share Posted May 26, 2024 Link to comment Share on other sites More sharing options...
