38-Improving the wiper motor ground
  • 1 year later...
I've pieced together what cruiser was intending for this tip. He has a short explanation in this post above:
It helps if you add a ground directly from the wiper motor ground point to a wiper pivot mounting screw.
Otherwise, the ground is running from the motor, to the right inner fender, across the front and to the left inner fender.
This writeup here is also fantastic for a total overhaul, but still goes into detail about adding a second ground for the wiper motor:
