fiatslug87 Posted May 24, 2024 Share Posted May 24, 2024 If anyone has this please post. Link to comment Share on other sites More sharing options...
hgeranium Posted November 11, 2025 Share Posted November 11, 2025 I've pieced together what cruiser was intending for this tip. He has a short explanation in this post above: It helps if you add a ground directly from the wiper motor ground point to a wiper pivot mounting screw. Otherwise, the ground is running from the motor, to the right inner fender, across the front and to the left inner fender. This writeup here is also fantastic for a total overhaul, but still goes into detail about adding a second ground for the wiper motor: Link to comment Share on other sites More sharing options...
