moonchild Posted April 10, 2006 Share Posted April 10, 2006 On a 4WD is the rear axle mounted above or below the leaf springs? Link to comment Share on other sites More sharing options...
87manche Posted April 10, 2006 Share Posted April 10, 2006 all Mj's are spring UNDER axle from the factory. Going spring over axle is good for about 5 inches of lift. Link to comment Share on other sites More sharing options...
Pete M Posted April 10, 2006 Share Posted April 10, 2006 4wd leaf packs do have about an inch more lift than 2wd models. Also, if you didn't already know, the XJ leaf perches are different width apart, so you can't just get an XJ axle (which are SOA) and bolt it up. Jeep on! --Pete Link to comment Share on other sites More sharing options...
