fiatslug87 Posted May 24, 2024 Share Posted May 24, 2024 If anyone has this please post. Link to comment Share on other sites More sharing options...
hgeranium Posted November 11, 2025 Share Posted November 11, 2025 Cruiser never made an official writeup for this but through multiple posts he and others gave enough information. I'll try my best to compress the information so this topic is a one-stop-shop for curious onlookers and link all the threads at the end. The method that cruiser toyed around with involves retaining the closed renix radiator, but adding an inline radiator hose filler, an overflow tank, and a couple of molded heater hoses. The part numbers are here: 11038 heater hose 11039 heater hose 63745 Moroso inline rad hose filler (on the upper rad hose) 730-4514 2.5 reservoir (7304514 is an alternative, just depends on where you can fit the tank; the closer to the moroso the better!) 703-1698 rad cap He also mentions that, while you're doing this, you can switch to "97 [heater] hoses [to] get rid of all that mumbo jumbo crap of the Renix hoses.", although not necessary. It's an easy way to delete the HCV with minimal work. ^ This is cruiser's picture using the 7304154 NAPA overflow tank. There is another example that I will put below. "Used a tank from a Cherokee and placed it where the old one was." Moroso Example of the 2.5 coolant tank as overflow below vvvv; bolts right in. You can also reuse the expansion tank as overflow: "Cleanest and easiest install IMO is to repurpose existing pressure bottle with $5 worth of parts. You don't have to relocate fuel pump ballast resistor or anything else on driver side fender. A couple of clamps and a nylon reducer and the pressure tank becomes the overflow bottle. " Another, albeit more expensive, method involves simply installing a Macs coolant tank and the 2.5 overflow tank, as done by PIKE: However, the moroso serves the same purpose as the macs, but at a much cheaper price; just requires a few more parts. If I'm missing something or get something completely wrong please tell me in the comments! I haven't done this myself so if anyone that has experience can make a step-by-step guide, that would greatly help the cohesiveness of this jumbled mess of a post lol. For some, it may be easier to just go through all the posts that I linked. Link to comment Share on other sites More sharing options...
