DesertComanche86 Posted May 13, 2024 Share Posted May 13, 2024 Hello everyone, I'm about to purchase and install RUSTY'S MJ COMANCHE 4.5" SPRING PACK KIT on my 1987 Jeep Comanche Pioneer 4x4 Automatic with the Dana 44 in the rear. Based on what I know, this truck is pretty much stock and the Dana 44 is original. Once I get Rusty's 4.5 Lift Kit installed, I want to get 32" tires on it... should I regear my differentials? If so, what should I regaer them to? IMG_5445.pdf Link to comment Share on other sites More sharing options...
Pete M Posted May 13, 2024 Share Posted May 13, 2024 right now you should have 3.55s and I would do 4.10s. double check what you have though. also, your brake prop arms should be in the other orientation with the big arm pointed to the pass side and the skinny rod pointed straight up. Link to comment Share on other sites More sharing options...
DesertComanche86 Posted May 13, 2024 Author Share Posted May 13, 2024 Thanks Link to comment Share on other sites More sharing options...
