Joe Dirt Posted December 26, 2023 Share Posted December 26, 2023 My rig is an 87-4.0, 5 speed. I have a 96 cherokee 4.0 H.O, 5 speed. I'm curious on what motor parts will work on my renix. Thermostat housing? Oil filter housing? I want to swap transmissions but i believe pete m has the swap info for that. I really need to get moving on my rig b4 she dyes on me.... Thanks for your time and any info will be appreciated 👍 Link to comment Share on other sites More sharing options...
cruiser54 Posted December 26, 2023 Share Posted December 26, 2023 Is your engine bad? Oil filter housing will work but no point in changing it that I see. Thermostat housing will fit but it has a sensor in it you won't be using. Link to comment Share on other sites More sharing options...
Joe Dirt Posted December 26, 2023 Author Share Posted December 26, 2023 Someone put my temp sensor in the radiator. The 1 in block is broke. Seems like my oil filter housing is leaking and the renix is vertical n the H.O is horizontal witch i like just personal preference just a thought that all the oil won't drain back... I gotta pull the thermostat housing cause my truck doesn't get hot. Idk if its stuck open or someone pulled it out. Truck is a basket case but I'm chipping away at it lil by lil Link to comment Share on other sites More sharing options...
cruiser54 Posted December 26, 2023 Share Posted December 26, 2023 Oil won't drain back if you use a quality oil filter. If you wanna use the common later oil filter, do this. CRUISER'S MOSTLY RENIX TIPS RENIX OIL FILTER TO SAE FILTER JANUARY 3, 2016 CRUISER54 9 COMMENTS EDIT Tired of having a poor selection of oil filters for your Renix Jeep? Limited availabilty a pain for you? 20mm threads? We don’t need mumblemeter threads on our oil filters. Here’s a simple mod that allows you to use the very popular SAE threaded oil filters which are more readily available. The old standard 3/4″ SAE thread. You can purchase a new oil filter nipple from the dealer for under $10 and never be bothered again. Part number 53007563AB. It’s the one on the left. Or, grab one off a 91 and later XJ at the junkyard. Be forewarned though. You need a 7/8 wrench to remove a Renix nipple, but a 15/16 wrench for the later style. And just in case you need to replace your oil filter adapter o-rings, here’s a handy guide. Oil Filter Adapter O-Ring Sizes 87-90 Renix Model O-rings 0.799 x 0.103 AS568 size -117 1.296 x 0.139 AS568 size -219 2.484 x 0.139 AS568 size –230 Dealer Part Numbers for Renix. Sold individually: 33002970, 33002971, 33002972 Renix kit from Crown Automotive-33002970K 91-01 HO Model Orings 0.676 x 0.070 AS568 size -017 0.859 x 0.139 AS568 size -212 2.484 x 0.139 AS568 size -230 Link to comment Share on other sites More sharing options...
