Bonkers Posted November 5, 2023 Share Posted November 5, 2023 1988 Base LWB 4x4 4.0 - I am the current owner (again.) I named her Gracie. I bought Gracie from a Chrysler Dealership in Bridgeville Delaware on January 22, 1999 with 113,555 on the odometer. I was told she was a trade in from a gentleman from Philadelphia. Due to hardship i was forced to trade her in to a Dealership in Townsend Delaware for a work truck. I immeditately regretted it. On December 03, 2000 the use of Amsoil caused the motor to blow up which resulted in a full motor rebuild. During that time i replaced the faulty odometer with a replacement full cluster. It changed the odometer from 138,715 to 117,645. At the time of sale she had a showing mileage reading of 131,732 or 152,802 (adjusted.) The repairs done during this ownership period were: (Oil) - Mobil 1 Oil 10w-30 - 09/17/2003 (Oil) - Mobil1 Filter M1-207 - 09/17/2003 (Repair) - Mopar Headlamp - L00H6054 - 09/17/2003 (Used) - AX15 Transmission - 06/4/2003 (Oil) - Mobil 1 Oil 10w-30 - 05/31/2003 (Oil) - Mobil1 Filter M1-207 - 05/31/2003 (Oil) - Mobil 1 Oil 10w-30 - 05/19/2003 (Oil) - Mobil1 Filter M1-207 - 05/19/2003 (Used) - Steering Wheel - 02/19/2003 (Labor) - Manual Transmission Service - GL5 - 01/12/2003 (Oil) - SuperFlo Oil 05w-30 (Jiffy Lube Lewes, DE) - 01/12/2003 (Oil) - SuperFlo Oil 05w-30 (Jiffy Lube Lewes, DE) - 10/27/2002 (Repair) - Excel Alternator - 7902 - 10/5/2002 (Labor) - Turn Signal Repair - 09/20/2002 (Used) - Seat Belt - 09/19/2002 (Used) - Side Mirror - 09/19/2002 (Used) - OEM AM/FM Cassette Radio - 08/19/2002 (Repair) - Anco Wiper Blade - U-18R - 08/18/2002 (Repair) - Anco Wiper Blade - U-22R - 08/18/2002 (Upgrade) - ARB Snorkel Install - 08/14/2002 (Battery) - Astrolite Battery - 58-60 - 08/13/2002 (Repair) - AMGauge Hose Clamps - 10 (2x) - 08/13/2002 (Repair) - AMGauge Hose Clamps - 32 (2x) - 08/13/2002 (Repair) - AMGauge Muffler Clamps - 225 (2x) - 08/13/2002 (Repair) - Walker Catalytic Converter - 15634 - 08/13/2002 (Repair) - Walker Front Pipe - 44320 - 08/13/2002 (Repair) - Walker Gasket - 31362 - 08/13/2002 (Repair) - Walker Gasket - 31519 - 08/13/2002 (Repair) - Walker SoundFX Muffler - 18113 - 08/13/2002 (Repair) - Walker Tail Pipe - 47605 - 08/13/2002 (Upgrade) - 8-Ball Shift Knob - 08/13/2002 (Repair) - A1 Cardone Brake Booster - 50-4071 - 07/26/2002 (Labor) - Front Bumper Removal - 05/01/2002 (Labor) - Oil Change - 05/01/2002 (Labor) - Slave Cylinder - 05/01/2002 (Labor) - Steering Wheel Removal - 05/01/2002 (Labor) - Turn Signal Repair - 05/01/2002 (Oil) - Kendall Oil 10w30 (Jiffy Lube Lewes, DE) - 05/01/2002 (Oil) - NAPA Proline Oil Filter - SFI21626 - 05/01/2002 (Repair) - Dorman Clutch Master - 39645 - 05/01/2002 (Repair) - Dorman Clutch Slave - 37916 - 05/01/2002 (Repair) - NAPA Turn Signal Socket - LS6447 (2x) - 05/01/2002 (Repair) - Sosmetal Drain Plug Gasket - 323224 - 05/01/2002 (Repair) - Sylvania Bulb - 1157 (2x) - 05/01/2002 (Repair) - Sylvania Bulb - 1157NA (2x) - 05/01/2002 (Repair) - Autolite Spark Plugs - 3924 (6x) - 04/08/2002 (Repair) - Champion Plug Wires - 780409 - 04/08/2002 (Repair) - Fram Air Fliter - CA3901 - 04/08/2002 (Repair) - Standard Distributor Cap - FD169 - 04/08/2002 (Repair) - Standard Distributor Rotor - FD308 - 04/08/2002 (Labor) - Motor Rebuild - 12/15/2000 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 11/12/2000 (Oil) - Fram Oil Filter - PH3985 (Jiffy Lube Lewes, DE) - 11/12/2000 (Labor) - Engine Flush - 07/03/2000 (Repair) - Sylvania Headlamp - H6054 - 05/16/2000 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 04/20/2000 (Oil) - Fram Oil Filter - PH3985 (Jiffy Lube Lewes, DE) - 04/20/2000 (Labor) - Rear Differential Service - GL7 (Jiffy Lube Lewes, DE) - 12/7/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 12/7/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 10/22/1999 (Tires) - Alignment - 10/15/1999 (Tires) - Bridgestone Dueler APT - 225/60R16 (4x) - 10/15/1999 (Tires) - Tire Install Z - Sears Dover Mall - 10/15/1999 (Upgrade) - JCW 8-Ball Shift Knob - 81DN7445B - 09/09/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 08/31/1999 (Brakes) - Brake Adjustment - 08/25/1999 (Brakes) - Front Brakes - 08/25/1999 (Labor) - Serpentine Belt - 07/07/1999 (Repair) - Serpentine Belt - 07/07/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 06/22/1999 (Oil) - Amsoil Oil 10w-30 (Jiffy Lube Lewes, DE) - 04/27/1999 (Repair) - Fuel Filter - 3/18/1999 (Repair) - Mopar PVC Tube - 4762592 - 03/18/1999 (Repair) - Mopar Vacuum Harness - 053004838 - 03/12/1999 (Repair) - Mopar Vacuum Harness - 053004868 - 03/12/1999 (Oil) - API Oil 10w-30 (Jiffy Lube Lewes, DE) - 03/04/1999 (Repair) - Autolite Spark Plugs - 3924 (6x) - 02/04/1999 (Repair) - GE Bulb - 2057NA - 02/04/1999 (Repair) - Standard Distributor Cap - FD169 - 02/04/1999 (Repair) - Standard Distributor Rotor - FD308 - 02/04/1999 (Oil) - Amsoil Oil - 10w-30 (Jiffy Lube Lewes, DE) - 01/28/1999 (Oil) - Fram Oil Filter - PH3985 - 01/28/1999 Link to comment Share on other sites More sharing options...
Bonkers Posted November 5, 2023 Author Share Posted November 5, 2023 After many years of searching i accidentally ran into Gracie again at a gas station. I gave the new owner my contact information and after a couple of months he reached out looking to sell. I picked her up from Kennett Square Pennsylvania on August 22, 2014 with 174,370 showing on the dash which should be the corrected mileage. She is currently at home in Georgetown Delaware and slowly... very slowly... being rebuilt back to mostly stock condition and as of this post has 181,432 on the dash. Current Repairs: (Battery) - Economy - 58RV - 06/04/2023 (Oil) - Mobil 1 Oil 10w-30 - 10/31/2022 (Repair) - Dorman 23.5g Fuel Tank - 576-660 - 10/20/2021 (Repair) - Dorman Fuel Tank Vent Valve - 911-060 - 10/20/2021 (Repair) - Duralast Fuel Filter - FF676DL - 10/20/2021 (Repair) - Fairchild Fuel Tank Vent Valve Gasket - F4111 - 10/20/2021 (Repair) - Goodmark Fuel Tank Strap Hook - GMK2111749681 - 10/20/2021 (Repair) - Spectra Premium Fuel Tank Strap Kit - ST117 - 10/20/2021 (Upgrade) - MTS Fuel Sender - JPSU-6P4.0 - 10/20/2021 (Oil) - Mobil1 Oil 10w-30 - 02/17/2021 (Oil) - WIX Oil Filter - 51626 - 02/17/2021 (Repair) - Crown Ballast Resistor - 33ddd682 - 02/17/2021 (Repair) - Map Sensor Bypass - 02/17/2021 (Repair) - Fel-Pro Throttle Body Gasket - 60742 - 01/16/2021 (Repair) - Walker CPS - 235-1096 - 01/16/2021 (Used) - OEM Throttle Body - 01/16/2021 (Used) - Tailgate Handle - 07/01/2019 (Repair) - Sylvania LED Bulbs - 1157 - 06/17/2019 (Upgrade) - JPN Wj LCAs - SCARK640773 (2x) - 05/18/2019 (Oil) - Mobil1 Oil - 10w-30 - 03/17/2019 (Oil) - WIX Oil Filter - 51626 - 03/17/2019 (Repair) - Dorman Headlight Adjusting Screws - 42185 - 02/25/2019 (Repair) - Dorman Headlight Adjusting Screws - 42185 - 02/25/2019 (Repair) - Crown Auto Header Panel - 83506616 - 02/10/2019 (Repair) - Crown Auto Accelerator Cable - 53005201 - 02/01/2019 (Repair) - AIP Elec TPS - TPS258 - 12/24/2018 (Repair) - Mopar Clutch/Master Cylinder - 52104110 - 10/21/2017 (Repair) - Mopar CPS - 33004761 - 10/21/2017 (Upgrade) - Warn Trans4mer Winch Carrier - PN29394 - 11/01/2016 (Upgrade) - Warn Trans4mer Grille Guard - PN39563 - 09/19/2016 (Upgrade) - Warn Trans4mer Grille Guard - PN39637 - 09/19/2016 (Used) - Rear Bumper - 09/10/2016 (Upgrade) - Scarborough Custom Hitch - 08/07/2016 (Labor) - Driveshaft Shortened 2.25in - 12/05/2015 (Repair) - ACDelco Pro U-Joint Clamp Kit - 45U0504 - 12/05/2015 (Repair) - ACDelco Pro U-Joint Clamp Kit - 45U0504 - 12/05/2015 (Repair) - LuK Clutch Kit - 05-901 - 11/01/2015 (Repair) - LuK Flywheel - LFW194 - 11/01/2015 (Repair) - Omix-Ada Clutch Fork - 16914.07 - 11/01/2015 (Repair) - Omix-Ada Pilot Bushing - 16910.04 - 11/01/2015 (Repair) - Sachs Clutch Master/Slave Assembly - SPH011 - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Repair) - Spicer U-Joint Kit - 5-153X - 11/01/2015 (Used) - Ax-15 Transmission - 11/01/2015 (Used) - LWB Roll Bar and Brackets - 06/26/2015 (Repair) - Omni Hub Assembly - PBR930049 - 05/15/2015 (Oil) - Mobil1 Filter - M1-207 - 03/21/2015 (Oil) - Mobil1 Oil - 10w-30 - 03/21/2015 (Repair) - RainX - Latitude 18" (x2) - 03/21/2015 (Repair) - Depo - Foglights - 03/1/2015 (Tires) - Goodyear Duratracs - 235/75/15 - 03/1/2015 (Used) - Replacement Rear Window - 11/01/2014 (Used) - Used Bumper Brackets - 11/01/2014 (Repair) - Standard IAC Valve - AC12 - 10/10/2014 (Used) - Window Regulator - 10/10/2014 (Repair) - Crown Auto Hood Prop Rod Holder - 55027404 - 09/14/2014 (Repair) - Crown Auto Parking Lens Screw Set - 6034204 - 09/14/2014 (Repair) - Crown Auto Radiator Grille [Black] - 55013145 - 09/14/2014 (Repair) - Door Panel 13-PC Fastener Set - 34201681 - 09/14/2014 (Repair) - Evan-Fischer FLH Bumper Bracket - EVA18072015354 - 09/14/2014 (Repair) - Evan-Fischer FLH Bumper End - EVA17172010446 - 09/14/2014 (Repair) - Evan-Fischer FRH Bumper Bracket - EVA18072010428 - 09/14/2014 (Repair) - Evan-Fischer FRH Bumper End - EVA17172010445 - 09/14/2014 (Repair) - Evan-Fischer Radiator Fan - EVA24572042267 - 09/14/2014 (Repair) - Front Bumper Face Bar - CH1002169 - 09/14/2014 (Repair) - Omix-Ada Bumper Guard - 12035.34 - 09/14/2014 (Repair) - Omix-Ada Bumper Guard - 12035.35 - 09/14/2014 (Repair) - Omix-Ada Headlight Bezel - 12419.09 - 09/14/2014 (Repair) - Omix-Ada Headlight Bezel - 12419.10 - 09/14/2014 (Repair) - Omix-Ada Serpentine Belt - 17111.04 - 09/14/2014 (Repair) - Side Marker Screw Set - 34201406 - 09/14/2014 (Repair) - Sun Visor Clip Set - DF49JS1 - 09/14/2014 (Repair) - White Knight Bulge Acorn Lug Nut - 1704S-20AM - 09/14/2014 (Used) - OEM Gas Tank Skid Plate - 09/14/2014 Link to comment Share on other sites More sharing options...
jdog Posted November 12, 2023 Share Posted November 12, 2023 BODY: JL62 BUILD: 10/7/87 SELLING DEALER: SALISBURY JEEP EAGLE SALISBURY, MD *X3 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE AGC APA MONOTONE PAINT BCQ MAINTENANCE FREE BATTERY CBA STRAIGHT BACK BENCH SEAT CGX DDQ 5-SPEED MANUAL TRANSMISSION ERB 4.0L I6 MPI ENGINE GAC TINTED GLASS WINDOWS HAA AIR CONDITIONING JJA CIGAR LIGHTER LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAA FEDERAL EMISSIONS NHQ TRANSMISSION HEATER PS4 QS4 RAB OPEN SBA POWER STEERING TBG COMPACT SPARE TIRE WJD 15X7.0 STYLED STEEL WHEELS Link to comment Share on other sites More sharing options...
