1JTMW6455JT201268
Bonkers
1988 Elminator
(I would be interested in purchasing this truck back)
I named her Scarlet
I first purchased Scarlet from a Private Seller in Long Neck
Delaware on June 05, 2001 with 89,995 miles on the
odometer. She was my daily driver until July, 05, 2002 and
was sold to an Electrical Contractor in Ellendale Delaware
with 115,968 showing.
During that time i did the following repairs:
(Oil) - Mobil1 Oil - 05w-30 - 04/13/2002
(Repair) - Standard Distributor Rotor - FD308 - 02/15/2002
(Repair) - Standard Distributor Cap - FD169 - 02/15/2002
(Repair) - Autolite Spark Plugs - 3924 (6x) - 02/15/2002
(Repair) - Autolite Plug Wires - 86624 - 02/15/2002
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 01/21/2002
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 01/16/2002
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 12/27/2001
(Repair) - Fram Air Filter - MA3901 - 12/1/2001
(Oil) - SuperFlo Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 12/01/2001
(Used) - Brush Guard - 11/30/2001
(Repair) - Mopar Speedo Cable - 04897729AA - 11/9/2001
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 11/01/2001
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 10/25/2001
(Oil) - SuperFlo Oil 10w-30 (Jiffy Lube, Lewes, DE) - 09/17/2001
(Battery) - Battery Install - 09/10/2001
(Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 09/07/2001
(Tires) - Correct Rim Install - 08/27/2001
(Labor) - Muffler and Steer Shock - 08/20/2001
(Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 08/19/2001
(Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 08/01/2001
(Labor) - Clutch Repair    Z - 07/17/2001
(Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 07/06/2001
(Repair) - A/C Repair - 07/05/2001
(Repair) - A/C Repair - 06/20/2001
(Oil) - API Oil - 10w-30 (Jiffy Lube, Lewes, DE) - 06/08/2001
(Labor) - Radiator Flush - 06/08/2001
(Labor) - Rear Differential Service - GL6 - 06/08/2001
I purchased this same truck again on March 03, 2014 from an
Auction House in Lincoln Delaware. She had 136,589 on the
odometer. She was in rough shape and my intention was to
restore it, but for the second time i lost my job and was forced
to sell her. She never got back on the road with me, but i did
do several repairs in the meantime. I sold her to a guy in
Owens Mills Maryland on March 28, 2020 who said he was
going to swap an LS and drive it - he did not an parted her
out. If the cab/frame still exist somewhere i would like the
truck back. She had 136,672 last i saw her.
Repairs i did during this ownership period:
(Used) - Tailgate Handle - 03/28/2020
(Used) - Steering Column - 03/28/2020
(Used) - Headliner - 03/28/2020
(Repair) - ACC Carpet Kit - 8019-Mist Grey Plush Cut Pile - 03/28/2020
(Labor) Fuel Pump Rebuild - 03/13/2020
(Labor) Driver Floor Patch - 03/13/2020
(Oil) - Wix Oil Filter - 51626 - 04/10/2019
(Oil) - Mobil1 Oil - 10w-30 - 04/10/2019
(Repair) - ACDelco Battery Shims - 04/08/2018
(Upgrade) - Speed Dawg Shift Knob Adapter Kit - 09/25/2017
(Upgrade) - American Shifter Red 7 Billiard Shift Knob - 96052 - 09/25/2017
(Repair) - ACDelco Battery Cable - 4BC41X - 07/05/2017
(Repair) - Mopar Wiper Breaker - 56001110 - 07/05/2016
(Brakes) - Wagner Brake Hose - BH113144 - 06/13/2016
(Brakes) - ACDelco Brake Wheel Cylinder - 18E1342 - 06/13/2016
(Brakes) - ACDelco Brake Wheel Cylinder - 18E1337 - 06/13/2016
(Brakes) - ACDelco Brake Spring Kit - 18K562 - 06/13/2016
(Brakes) - ACDelco Brake Adjuster Kit - 18K7 - 06/13/2016
(Brakes) - ACDelco Brake Adjuster Kit - 18K6 - 06/13/2016
(Repair) - Dorman HELP! Jeep Vacuum Harness - 46004 - 06/01/2016
(Repair) - Dorman HELP! Jeep Vacuum Harness - 46003 - 06/01/2016
(Repair) - Dorman HELP! Crankcase Vent Tube - 46005 - 06/01/2016
(Brakes) - 3/16 CNC Brake Line - 06/01/2016
(Upgrade) - Depo Foglights - 04/01/2016
(Repair) - BCP 5 Weatherproof Electrical 2 Pin Way Connector - 04/01/2016
(Repair) - 2P Male Black 20 AMP Connectors - 04/01/2016
(Used) - Eliminator Door Panels - 03/20/2016
(Repair) - Omix-Ada Windshield Molding - 12035.58 - 03/20/2016
(Repair) - DB Electrical Alternator - ADR0026 - 03/20/2016
(Repair) - Dayco Serpentine Belt - 5061025 - 03/20/2016
(Repair) - Windshield Adhesive - HAH000004 - 03/20/2016
(Repair) - Windshield - DW01140GBN - 03/20/2016
(Oil) - Mobil1 Oil - 10w-30 - 03/21/2015
(Oil) - Mobil1 Filter - M1-207 - 03/21/2015
(Repair) - TeamXj Sun Visor Clip Set - DF49JS1 - 09/13/2014
(Repair) - Omix-Ada Serpentine Belt - 17111.04 - 09/13/2014
(Repair) - Omix-Ada Bumper Guard - 12035.35 - 09/13/2014
(Repair) - Crown Auto Radiator Grille [Black] - 55013145 - 09/13/2014
(Repair) - Crown Auto Parking Lens Screw Set - 6034204 - 09/13/2014
(Repair) - Crown Auto Hood Prop Rod Holder - 55027404 - 09/13/2014
(Repair) - Walker U-Bolt Exhaust Clamp (x2) - 35413 - 07/05/2014
(Repair) - Walker Tail Pipe - 46701 - 07/05/2014
(Repair) - Walker SoundFX Muffler - 18387 - 07/05/2014
(Repair) - Walker Hardware Insulator - 35750 (2x) - 07/05/2014
(Repair) - Walker Exhaust Pipe - 44320 - 07/05/2014
(Repair) - Walker Exhaust Gasket - 31362 (2x) - 07/05/2014
(Repair) - Walker Catalytic Converter - 15634 - 07/05/2014
(Repair) - White Knight Bulge Acorn Lug Nut - 1704S-20AM - 06/27/2014
(Repair) - TYC Pass Side Marker Lamp - 18-3183-01 - 06/27/2014
(Repair) - TYC Driver Side Marker Lamp - 18-3184-01 - 06/27/2014
(Repair) - Parking Light Bulb Socket - 06/27/2014
(Repair) - Omix-Ada Flasher Relay - 12411 - 06/27/2014
(Repair) - Dorman Parking Brake Cable - C93591 - 06/27/2014
(Repair) - Dorman Hood Release Cable - 912-008 - 06/27/2014
(Used) - Tilt Column (Tan) - 03/20/2014
(Used) - Taillights - 03/20/2014
(Tires) - Scrub Tires - 03/20/2014
(Repair) - Magnecor Wire Set - 6044 - 03/20/2014
(Repair) - Fram Fuel Filter - G3641 - 03/20/2014
(Repair) - Fram Air Filter - CA3901 - 03/20/2014
(Repair) - Champion Spark Plugs - RC9YC (4x) - 03/20/2014
(Repair) - Champion Spark Plugs - RC9YC (2x) - 03/20/2014
(Repair) - Accel Distributor Cap - 120330 - 03/20/2014
(Oil) - Mobil1 Filter - M1-207 - 03/20/2014
(Oil) - Excel Oil - 10w-30 - 03/20/2014
(Repair) - Dorman Wiper Blade Arm - 03/10/2014
BODY: TS61
BUILD: 05/07/88
SELLING DEALER: ATLANTIC CHRYSLER JEEP DODGE RENAULT
EGG HARBOR TOWNSHIP, NJ
Q7 CLOTH LOW-BACK BUCKET SEATS -SA CHARCOAL AGD
APA MONOTONE PAINT CAC LOW BACK BUCKET SEATS CGW
CKA CARPETS - FLOOR AND CARGO AREA CUF FULL LENGTH FLOOR CONSOLE DDJ DESCRIPTION NOT AVAILABLE
ERB 4.0L I6 MPI ENGINE GAC TINTED GLASS WINDOWS GEC FRONT LEFT SIDE SLIDING WINDOW
GFD REAR SLIDING WINDOW GPB FOLD  MRRS JFH TACHOMETER
JGB PERFORMANCE DATA VIDEO RECORDER JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER
K60 STRIPE/BADGE/MOLDING LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS
LNJ FRONT FOG LAMPS MBJ BLACK FRONT BUMPER MCA
MCB   MDA FRONT LICENSE PLATE BRACKET NAA FEDERAL EMISSIONS
PE4 Colorado Red QE4 Colorado Red RAF OPEN
SBA POWER  STEERING SCE STEERING WHEEL SUA TILT STEERING COLUMN
TBG COMPACT SPARE TIRE WJH 15X7 ALUMINUM WHEELS 3LY DESCRIPTION NOT AVAILABLE
