Bonkers Posted November 5, 2023 Share Posted November 5, 2023 1988 SWB Pioneer 4x4 I named her Carmine. She was purchased from a private seller in Norristown Pennsylvania on October 15, 2006 and sold to a gentleman in West Virginia on June 29, 2007. She came with 142,820 on the odometer and left with 143,833. In my care she had the following repairs: (Used) - Wj Control Arms - 05/31/2007 (Repair) - Rear Main Seal - 10/3/2006 (Tires) - Used Tires - 10/1/2006 (Repair) - Window Seals - 09/1/2006 (Repair) - Floor Pans - 09/1/2006 (Repair) - Wiper Blades - 08/31/2006 (Repair) - Sylvania Bulb - H6054 - 08/31/2006 (Brakes) - UBP Brake Shoes - 151R - 08/26/2006 (Brakes) - Raymold Wheel Cylinders (2x) - 08/26/2006 (Brakes) - Raybestos Spring Kit - H7064 - 08/26/2006 (Repair) - Walker Tail Pipe - 46701 - 01/4/2006 (Repair) - Walker SoundFX Muffler - 18113 - 01/4/2006 (Repair) - Walker Catalytic Converter - 15634 - 01/4/2006 (Repair) - AMGauge Muffler Clamps - 225 - 01/4/2006 (Repair) - Walker Gasket - 31519 - 11/25/2005 (Repair) - Walker Gasket - 31362 - 11/25/2005 (Repair) - Walker Front Pipe - 44320 - 11/25/2005 (Repair) - Monroe Steer Shock - SC2928 - 11/25/2005 (Repair) - Dayco Idler Pulley - 89006 - 11/25/2005 (Repair) - Bussman Fuse - 552 - 11/25/2005 (Repair) - Dorman Vacuum Harness - 11/4/2005 (Tires) - Used Tires 10/27/2005 (Repair) - Mopar Water Pump Gasket - 53020420 - 10/27/2005 (Repair) - Mopar Water Pump - 4626215AB - 10/27/2005 (Repair) - Mopar Thermostat Gasket - 53020547AC - 10/27/2005 (Repair) - Mopar Coolant Overflow - 758977K - 10/27/2005 (Repair) - Crown Auto Thermostat - 83501426 - 10/27/2005 (Oil) - Oil Change (Jiffy Lube Lewes,DE) - 10/27/2005 (Repair) - Standard Rotor - 10/17/2005 (Repair) - Standard Distributor Rotor - FD308 - 10/17/2005 (Repair) - Standard Distributor Cap - FD169 - 10/17/2005 (Repair) - Standard Cap - 10/17/2005 (Repair) - Fram Fuel Filter - G3641 - 10/17/2005 (Repair) - Autolite Wires - 10/17/2005 (Repair) - Autolite Spark Plugs - 3924 (6x) - 10/17/2005 (Repair) - Autolite Plug Wires - 96624 - 10/17/2005 (Repair) - Autolight Spark Plugs - 10/17/2005 Link to comment Share on other sites More sharing options...
jdog Posted November 12, 2023 Share Posted November 12, 2023 BODY: JM61 BUILD: 08/19/88 SELLING DEALER: BRADY-BUSHEY JEEP CHARLOTTESVILLE, VA *X1 DESCRIPTION NOT AVAILABLE -SA CHARCOAL ADB PROTECTION GROUP ADLA SKID PLATE GROUP AHL HEAVY DUTY INSULATION GROUP ALN BUMPER GROUP BAYP 105 AMP ALTERNATOR BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT CLAP FRONT FLOOR MATS DBBC ALL MANUAL TRANSMISSIONS DDX 5-SPEED HD MANUAL TRANSMISSION EAAC ALL ENGINES EAFC ERB 4.0L I6 MPI ENGINE GEC FRONT LEFT SIDE SLIDING WINDOW GFDA REAR SLIDING WINDOW GRCP GSCP RIGHT BLACK MIRROR GTCA MANUAL MIRRORS HAA AIR CONDITIONING HGAP HOOD INSULATION JAYA DO NOT USE - SEE JP, KA CLASSES JGBP JHAA VAR INTERMITTENT WINDSHIELD WIPERS MCAP MDAP FRONT LICENSE PLATE BRACKET MMPP BRIGHT DAY LIGHT OPENING MOLDINGS PE4 Colorado Red RAAC ALL RADIO EQUIPPED VEHICLES RAF OPEN RCDP 4 SPEAKERS SUA TILT STEERING COLUMN TAAC ALL TIRES TBBA FULL SIZE SPARE TIRE TMWA TIRES WJM 15X7.0 CHROME WHEELS XEEP FUEL TANK SKID PLATE SHIELD XEFP TRANSFER CASE SKID PLATE SHIELD XEUP FRONT SUSPENSION SKID PLATE YGGA 9 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z66P LEFT FRONT GROUP XV Z85P RIGHT FRONT SPRING GROUP XIV 5AMA JF/3450 VEHICLE FAMILY 5KNA APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES BJAS DESCRIPTION NOT AVAILABLE BKPS 10X2.5 REAR DRUM BRAKES CKAS CARPETS - FLOOR AND CARGO AREA CSRS PASSENGER ASSIST HANDLES CUMS MINI FLOOR CONSOLE DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE DMMS 3.07 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GNAS REAR VIEW DAY/NIGHT MIRROR JAAS INSTRUMENT PANEL JBDS INSTRUMENT PANEL SATIN SILVER BEZEL JCAS 85 MPH PRIMARY SPEEDOMETER JJAS CIGAR LIGHTER JKBS KKES DESCRIPTION NOT AVAILABLE K2XS STRIPE/BADGE/MOLDING/COLOR K3RS STRIPE/BADGE/MOLDING/COLOR LAFS SEAT BELT ALERT-DRIVER SEAT ONLY LAPS SHIFT INDICATOR WARNING LAMP LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MBJS BLACK FRONT BUMPER MB1S BLACK BUMPER MFGS HEADLAMP BEZELS MHAS BLACK WINDSHIELD MOLDINGS MMCS MMGS BELT MOLDINGS MMKS NAAS FEDERAL EMISSIONS NBAS UNDERGROUND CALIBRATION NBKS EVAP CONTROL SYSTEM NDAS CATALYTIC CONVERTER NF2S 18 GALLON FUEL TANK QE4S Colorado Red SBAS POWER STEERING SCES STEERING WHEEL SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH XBSS PICKUP BOX XFAS -35F PROTECTION ANTI-FREEZE YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 135S ZONE 35-WASHINGTON Link to comment Share on other sites More sharing options...
