I have a bad oil leak on 1986 Comanche V6 2.8L. I thought it was the valve cover gaskets and that was a real headache.
Can someone please help me locate the Oil pressure sending unit? It might be leaking from there.
Plus I am sure that this topic has already been discussed but I'm having difficulty finding this feed. Seems to me that someone has had a problem with this before.
It's located on the driver side of the block by the engine mount. There will be a single wire running down to it20200503_173955.jpg.687005d5c8f166d575a71c2235b0ed29.jpg
It's hard to see but it is right under the blue oil filter.
It will be different sizes depending on if you have dummy lights of gauges. This one is gauges.
  • 4 weeks later...
