GTGMJ Posted July 13, 2023 Share Posted July 13, 2023 I'm in the market for new seatbelts. For those that got the 2 door Cherokee kit from seatbeltplanet.com, did you get Bolt Down Ends (kit # DJP13), or Loop Ends (kit# DJP19)? I want to make sure I order the correct kit for my Comanche. Also, please share if anyone has a part number for the correct replacement from seatbeltsplus.com. They are quite a bit cheaper, so I may consider them an option. Thanks! Link to comment Share on other sites More sharing options...
Pete M Posted July 13, 2023 Share Posted July 13, 2023 6 minutes ago, GTGMJ said: I'm in the market for new seatbelts. For those that got the 2 door Cherokee kit from seatbeltplanet.com, did you get Bolt Down Ends (kit # DJP13), or Loop Ends (kit# DJP19)? I want to make sure I order the correct kit for my Comanche. Also, please share if anyone has a part number for the correct replacement from seatbeltsplus.com. They are quite a bit cheaper, so I may consider them an option. Thanks! I split your post off into it's own topic so more eyeballs might see it. Link to comment Share on other sites More sharing options...
GTGMJ Posted July 13, 2023 Author Share Posted July 13, 2023 Thanks Pete. And thanks to all of you Comanche gurus that are helping me get my 4x4Rat sorted out! Link to comment Share on other sites More sharing options...
AZJeff Posted July 14, 2023 Share Posted July 14, 2023 When I put new seat belts in my MJ, I went with stuff from Seat Belts Plus. Here is exactly what I ordered, but you can adjust to meet your needs: MJ Seat Belts Link to comment Share on other sites More sharing options...
GTGMJ Posted July 15, 2023 Author Share Posted July 15, 2023 Thanks AZJeff! I'm assuming you have a bench? I've got buckets, so I'm leaning towards these... https://www.seatbeltplanet.com/i-30497868-1984-1996-jeep-cherokee-2-door-front-seat-belt-kit-bolt-down-end-fittings.html?ref=category:1389249 I've been told by Kody Kilmer (the Facebook/Ebay used parts go-to guy) that our belts are bolt down end fittings, but the descriptions on seatbeltplus.com say nothing about being Loop Ends or Bolt Down Ends like the ones on seatbeltplanet.com. For only $75 more, I'd rather be certain. Link to comment Share on other sites More sharing options...
AZJeff Posted July 15, 2023 Share Posted July 15, 2023 2 hours ago, GTGMJ said: Thanks AZJeff! I'm assuming you have a bench? I've got buckets, so I'm leaning towards these... https://www.seatbeltplanet.com/i-30497868-1984-1996-jeep-cherokee-2-door-front-seat-belt-kit-bolt-down-end-fittings.html?ref=category:1389249 I've been told by Kody Kilmer (the Facebook/Ebay used parts go-to guy) that our belts are bolt down end fittings, but the descriptions on seatbeltplus.com say nothing about being Loop Ends or Bolt Down Ends like the ones on seatbeltplanet.com. For only $75 more, I'd rather be certain. I have buckets in my MJ, and I bought the kind where the inboard (female) half of the belt has a stiff cable covered with plastic that holds the buckle up where it can be reached easily. Link to comment Share on other sites More sharing options...
