Caliper mount to knuckle bolts
I am having a issue finding caliper bracket to knuckle mount bolts. They're 12 point 13mm bolts kinda like the hub to knuckle bolts.
Are there newer jeeps that run the same size bolts?
89 comanche.
I just went through this exact issue on my 89 MJ. Except mine were E-torx bolts.
The bolts are flanged M12 x 1.25 - 35mm length, grade 10.9
I went to the junkyard, there were no XJs so I grabbed two random bolts that were laying on the ground and matched the spec. I took one of my bolts there to compare.
12 hours ago, ghetdjc320 said:
Do you have 89 knuckles? New bolts normally come with the calipers. 89 was the last year for the old style.
I'm not talking about caliper to caliper bracket bolts, I'm talking about caliper bracket to knuckle bolts.
Looks like 91Pioneer is having the same issue!
Chris
I was thinking of just taking a bolt and heading down to the Auto Parts store and trying to figure it out.
So those worked ?
Chris
So those worked ?
Chris
They worked fine. I doubt an auto parts store will have them but you could try. A dedicated fastener store would be a better option. Grade 10.9, don’t get 8.8 which will be more common.
Chris
Thats why I asked if you had 89 knuckles. Can you snap a picture of the knuckles?
