Read a VIN?
Can anybody here read a VIN? I have a 92 eliminator and I know only 900 MJ's were made in 92, so I'd like to find out if mines an early, or a late year (end of the line so to speak) model.
here's the VIN
1J7-FJ66S1NL-142735 S.O NO. MJJ-JT22501
According to http://www.vehicleidentificationnumber.com/jeep_2.html, which I randomly found, this info came up for the first digits. Hope that helps with something.
Country:
USA
Manufacturer:
Jeep (USA)
Type:
TRUCK
GVWR (Gross Vehicle Weight Rating ):
1819-2272 kg
Model:
Cherokee - 4WD
Series:
Sport/Classic
Body type:
Comanche, 2-door pick-up
Engine:
4,0 litres, I-6, HO
Control digit:
Has passed check
Year:
1992
Plant:
Toledo #1
Serial number:
142735
If i remember correctly, the last six numbers (in your case 142735) are the number of vehichles assembled at the plant (Todelo in your case). Obviously, that is not the number of MJ's made for your year. Maybe thats a cummulative number for 86-92 Comanche's produced and/or they produced other vehicles there. This is speculative however without doing further research!
I used this site https://www.agedstock.com/main/vin.php
and here is what I got:
Vehicle Serial-Number 142735
Country of Origin United States of America
Manufacturing Plant Toledo #1:Toledo, OH
Model Name/Code COMA
Model Number MJJL61
Trim Level ELIM
Body Type Conventional Cab
Engine Description 4.0 Liter MPI
GVWR Weight Class 4,001 - 5,000 Lbs.
Chassis 4x4
Brake System Hydraulic
Number of Doors 2
Number of Cylinder 6
Parts Catalog Model Code J
Vehicle Class Pickup
Model Year 1992
Make Jeep
Model Comanche
Trim Eliminator
Model Details Comanche
Options Media: AM/FM Radio Tuner
Power Steering
Engine Cylinders 06
Doors Two
Power Brakes
Daytime Running Lights
Mine:
028948
Country of Origin
Manufacturing Plant
Toledo, OH
Model Name/Code
COMA
Trim Level
PION
Body Type
Long Bed
Engine Description
4.0 Liter MPI
GVWR Weight Class
4,001 - 5,000 Lbs.
Chassis
4x4
Brake System
Hydraulic
Number of Doors
2
Number of Cylinder
6
J
Vehicle Class
Pickup
Model Year
1987
Make
Jeep
Model
Comanche
Model Details
Liberty
Options
Power Steering
Engine Cylinders 06
Doors Two
Drive: Four Wheel Drive
Power Brakes
Seems pretty accurate, it is an 87 LWB pioneer.
Cool! Thanks for all the info.
I'm trying to find out the exact build date and I sent an email DC to ask for the build sheet. They were unable to find that, but they did go on to say that it appears to be an end of production number.
I have something wrong with my VIN too.
My comanche is a 1988 for export. I am in Argentina. VIN is 1JEYL631EJT2360003. The meaning of these 17 digits match the vehicle features but when I type the VIN in some VIN DECODER the answer is that the VIN is not recognized.
Does anybody know what could be the reason?
I would also like to get the build sheet of my truck. How can I get it?
Thank you
Fernando
id did find a copy of my buildsheet taped to the "inside" of the doorcover at the passenger side, try a look.
@ fernando is this the vin from the windshield?
in germany they don´t accept the US VIN and give them a new one
@ all i sometimes do have the feeling a Toledo, they did not only use whatever they did find at the shelf even they did use whatever number they thought of, without thinking if the number was correct
You could try going to your local Jeep dealers parts desk and asking...mine printed me out the build sheet for my '89 MJ.
Also a carfax report will tellyou when it was first registered, fwiw 8)
