Bomberjeep Posted April 5, 2023 Posted April 5, 2023 After replacing some leaking power steering lines and going to bleed the system I noticed a pinhole leak on the transmission cooler line. I’m trying to figure out how much pressure is actually in that system.
cruiser54 Posted April 5, 2023 Posted April 5, 2023 It's low enough that folks repair those metal lines with hose that's ATF compatible.
Bomberjeep Posted April 5, 2023 Author Posted April 5, 2023 4 minutes ago, cruiser54 said: It's low enough that folks repair those metal lines with hose that's ATF compatible. That’s what I was thinking of doing. Again you’ve been a big help! I'm guessing a fuel line would do the trick?
