harleysMJ Posted April 2, 2023 Posted April 2, 2023 Hey Gang, So I’ve been tinkering with my jeep and I’ve gotten the ignition system functioning however it still will not spark. I’ve checked the timing, replaced the coil, rotor bug, distributor cap, and crank shaft position sensor, along with making sure the wiring is set. Looking for suggestions or other potential issues I should check!
gogmorgo Posted April 2, 2023 Posted April 2, 2023 We’re gonna need more info. If you’ve got no spark your ignition system is not functioning. If you got your ignition system functioning, then you would have spark. Do you mean you have spark but the engine still won’t fire?
