Running wire from cab to rear
What's the best way to run a wire from inside the cab to the rear of the truck (for a brake controller)? There's the rubber plug where the rear harness goes through the cab, but I'm not sure if that's easy enough to use to run a couple more wires through?
I ended up soaping up the harness rubber plug and was able to fish a wire through using a coat hanger. Was definitely tight, but made it through. Did the same with the hood release grommet for going from the cab to the engine bay.
