jaystrawn135 Posted March 14, 2023 Posted March 14, 2023 89 comanche 4.0 2wd. So I had issues with my lock cylinder and the ignition switch. I got inside the dash and replaced them, but now the gauge lights and the tail lights don't come on when you pull the switch. I've checked the ground, the connection on the switch, and every connection I could find under the dash without tearing it back apart. Everything seems to be connected and the fuse is good. Am I possibility missing something or do I need a new switch? Seems like I'm probably missing something, but I was all under that dash and couldn't find anything out of sorts.
Ωhm Posted March 14, 2023 Posted March 14, 2023 8 minutes ago, jaystrawn135 said: and the fuse is good. Which fuse is good? Check the PARK fuse (10A).
jaystrawn135 Posted March 14, 2023 Author Posted March 14, 2023 1 hour ago, Ωhm said: Which fuse is good? Check the PARK fuse (10A). That's what it was, I had checked several of the fuses but not that one. Thanks for your help boss.
