Like the title says. Looking for the vac harness for the NP228/9 from 84-86 XJs. Doesn’t need to be the entire harness, can be just the connectors and I can make it work from there.
Different t-cases. One is selec-trac which is always in 4wd operation by the small lever on the console(not the shift handle) and the 207 is just like the 231 but less vacuum stuff.
