VorTekX Posted January 2, 2023 Posted January 2, 2023 I can't find any on the 88 comanche drop down menu unless I'm not looking in the right spot.
gogmorgo Posted January 2, 2023 Posted January 2, 2023 You're not wrong, they're not available as fitting an MJ. They do have a listing for the Cherokee, although it lists as fitting 84-01, which I don't know is accurate, unless it's the only thing in the knuckle/hub/brake assembly that stayed the same between the early and later setups. But they're not super expensive, and Rockauto is good about refunding parts that don't fit.
VorTekX Posted January 2, 2023 Author Posted January 2, 2023 11 hours ago, gogmorgo said: You're not wrong, they're not available as fitting an MJ. They do have a listing for the Cherokee, although it lists as fitting 84-01, which I don't know is accurate, unless it's the only thing in the knuckle/hub/brake assembly that stayed the same between the early and later setups. But they're not super expensive, and Rockauto is good about refunding parts that don't fit. A quick visual inspection from the ones on my truck seem to be identical to the ones on the 88 Cherokee menu. Will try these.
