jaystrawn135 Posted December 27, 2022 Share Posted December 27, 2022 I have a 88 jeep comanche 4.0, 2wd, automatic. When I'm put in park after driving the key doesn't want to turn off, and when starting it, it has to be in neutral or it won't start most days. Link to comment Share on other sites More sharing options...
Pete M Posted December 27, 2022 Share Posted December 27, 2022 starting in 'neutral' but not 'park' usually means it's time to clean the NSS. Link to comment Share on other sites More sharing options...
jaystrawn135 Posted December 30, 2022 Author Share Posted December 30, 2022 On 12/27/2022 at 7:27 AM, Pete M said: starting in 'neutral' but not 'park' usually means it's time to clean the NSS. Thanks boss, I'll look into that. What would be making the key stick in the run position though? I'm thinking it's either a ignition is worn or the ignition is not unlocking after being put in park. I know some of the newer vehicles have safeties like that but I didn't know if something this old would. Didn't want to throw parts at it so I figured I'd see if someone has ran into it before. Link to comment Share on other sites More sharing options...
Pete M Posted December 30, 2022 Share Posted December 30, 2022 it sounds like it's all worn out, but I'm no expert on the key cylinders. Link to comment Share on other sites More sharing options...
Eagle Posted December 31, 2022 Share Posted December 31, 2022 On 12/29/2022 at 10:54 PM, jaystrawn135 said: Thanks boss, I'll look into that. What would be making the key stick in the run position though? I'm thinking it's either a ignition is worn or the ignition is not unlocking after being put in park. I know some of the newer vehicles have safeties like that but I didn't know if something this old would. Didn't want to throw parts at it so I figured I'd see if someone has ran into it before. The Park interlock shouldn't affect turning the engine off. You can do that with the transmission in gear. The interlock only affects turn the key far enough to lock the steering column and remove the key. You may need to adjust the ignition switch push rod in the steering column, or you may need a new key cylinder. Link to comment Share on other sites More sharing options...
jaystrawn135 Posted January 15, 2023 Author Share Posted January 15, 2023 Awesome thanks guys, it was the ignition switch itself that was sticking after all. Still gotta take care of the nss, but I'll just put a new one on and clean the old one and keep it with my spare parts. Thanks for your time y'all. Link to comment Share on other sites More sharing options...
