Glenn Bint Posted November 25, 2022 Share Posted November 25, 2022 So… both of these gauges read poorly. Temp reads low and oil gauge reads high. Thought I saw something a little while back and grounding. Any suggestions? Link to comment Share on other sites More sharing options...
Burke Posted November 26, 2022 Share Posted November 26, 2022 Mostly Renix, but some will apply to H.O. https://cruiser54.com/ for grounding specifically see https://cruiser54.com/?p=19 Link to comment Share on other sites More sharing options...
Glenn Bint Posted June 11, 2023 Author Share Posted June 11, 2023 Thanks. I’ll check it out. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 13, 2023 Share Posted June 13, 2023 CRUISER'S MOSTLY RENIX TIPS IMPROVING THE INSTRUMENT PANEL GROUND NOVEMBER 17, 2015 SALAD 27 COMMENTS The ground point for the complete instrument cluster on your XJ or MJ is located up under the driver’s side dash. If you lay on your back and look up under there with a flashlight, without wearing a hat, you will see a black wire attached to a shiny piece of metal almost directly above the hood release knob. The screw will have either a ¼” or 5/16″ head on it. This ground point is responsible for handling the ground circuit for the following items: Dome lamps, seat belt and key warnings, transmission power/comfort switch, wiper switch, headlamp switch and delay module, fog lamp switch, cargo lamp switch, all instrument panel grounds and illumination, power windows and door locks, cruise control dump valve, and a few more things. The problem is that where the ground point is located does not share good contact with the chassis where the ground should be. The solution is simple: Make up a jumper wire with #10 gauge wire about 10″ long. On one end, crimp on a ¼” round wire terminal. On the other end, crimp on a 3/8″ round wire terminal. Remove the screw from the existing ground wire and attach the small terminal of your jumper so that the original wire and your new jumper share the same attaching point, one over the other. Look above the driver’s side plastic kick panel just forward of the top of the hood release knob. You will see an 8mm stud there. Attach the large terminal end there with a washer and nut over it tightened securely. Use a coating of OxGard at all ground contact surfaces when attaching the screw and nut. **Special note for Comanche owners: Make your jumper wire 12″ long and attach it on the driver’s side kick panel close to the fusebox on the 8mm stud.** Link to comment Share on other sites More sharing options...
