I recently picked up a 89 MJ project and have a couple questions. I got a Dana 44 rear out of a cherokee for it. Is there a bolt on disc brake swap i can put on the rear? Like maybe out of a ZJ. Would the wiring on a 89 and 90 steering column be the same as long as they are both automatics? Thanks for any help.
Yes and Yes...
The D44 swap is VERY COMMON and covered here ad nausium. Do some searching and youll find everything you need. if there are any spfic questions that come up, fire away!!
Comanches and Cherokes are almost adsolutely identicle from the doors forward.
Only thing that come to mind that are for sure different are actual floor boards and seat bases.
CW
