97+ wiring question
Just pulled the entire harness out of my 4-door 98 XJ organ donor for Project Scuzzy.
Question for those who have done this before. Did you strip down the harness to remove the unneeded connectors, or did you just leave everything and only connect what's needed?
I left everything as it was in the main harness, depending on the options you plan to use you will end up needing pretty much all of it anyway.  Any extra wires left in gives you options to add stuff later as well.
The block of plugs from near the rear gate fits behind the carpet panel on the back wall of the MJ but does bulge it out slightly.  Otherwise everything fits just like it's supposed to.
Obviously you can ditch the third brake light and rear wiper motor harness unless you plan to mount a third brake light.  Just leave the plugs unpopulated in the main harness.
