Front axle/Front suspension noise? plz help
ok well i got the hub off. one question is the axle supposed to just slide out of the housing really easy? Thats a shock to me, so i don't know.
if it doesn't then you have problems. ;) its all lubed up and fits right in, that huge nut is what keeps it in place.
a trick for the hub is to put anti-seize on the back of it before you install so that it won't get stuck, to remove THWACK! it with a BFH and it should pop right out.
