4.0 swap and thought I was all finished, went to take her on first drive but no brakes, bleed all the lines and re checked vacuum hoses, still nothing. Changed out booster, nothing. Press on pedal and goes all the way down and have a hissing noise when I press pedal, any idea’s?
Were the calipers removed and put back on during the swap? Check to see if you accidentally swapped calipers as there is a right one and a left one. Is the Brake Warning light on?
