1J7FJ36S0NL124984
sammisox
Body: jl61
Build: 08/30/91
Selling Dealer: WHITE CHRYSLER-PLYMOUTH-JEEP-EAGLE
Abilene, TX
APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission
DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle
DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass JAZS DO NOT USE - See JP, KA classes
JCAS 85 MPH Primary Speedometer KWSS STRIPE/BADGE/MOLDING/COLOR K3WS STRIPE/BADGE/MOLDING/COLOR
LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper
MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings
NAAS Federal Emissions NBKS EVAP Control System NF2S 18 Gallon Fuel Tank
QW7S Bright White Clear Coat SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers
SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail
163S Zone 63-Dallas
*C1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ADLP Skid Plate Group
ARLP   BARP 90 Amp Alternator BCDP 550 Amp Maintenance Free Battery
CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions
DHTP Shift-on-the-Fly,P/Time T/Case ERH 4.0L I6 Power Tech Engine GEC Front Left Side Sliding Window
GFDP Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror
GTZP Manual Remote Mirrors HAA Air Conditioning JHAP Var Intermittent Windshield Wipers
JJAP Cigar Lighter KKSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR
K27P Do Not Use MBJP Black Bumper MDAP Front License Plate Bracket
MHAP Black Windshield Moldings MMKP   PW7 Bright White Clear Coat
RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers
SBAP Power Rack and Pinion Steering SUA Tilt Steering Column TBBP Full Size Spare Tire
TMWP Tires TZHP Michelin Brand Tires WJDP 15X7.0 Styled Steel Wheels
WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I
Z66P Left Front Group XV Z83P Right Front Spring Group XII 2TEA Customer Preferred Package 2TE
26E Customer Preferred Package 26E 3VRA Customer Preferred Discount
