WranglerMangler Posted June 11, 2022 Share Posted June 11, 2022 Budget Truck Wrecking Auburn Wa Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 16, 2022 Share Posted June 16, 2022 What?! Has cruise but no AC. I need those cruise parts. *ZZ -ZZ AJT RADIO PREP GROUP AJY Popular Equipment Package BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual DMN 4.10 Axle Ratio EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN Build date 8/13/85 Body code JM62 Link to comment Share on other sites More sharing options...
WranglerMangler Posted June 17, 2022 Author Share Posted June 17, 2022 Exactly what do you need? I was going to go back down there this weekend. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 17, 2022 Share Posted June 17, 2022 10 minutes ago, WranglerMangler said: Exactly what do you need? I was going to go back down there this weekend. Everything attached. Solenoid, air cans, wiring harness, yellow box(actuator), brake switch, dump valve and clutch switch with brackets. Link to comment Share on other sites More sharing options...
WranglerMangler Posted June 17, 2022 Author Share Posted June 17, 2022 Excuse my ignorance but I’ve never dealt with the cruise control on the MJs. Is there a schematic or write up of parts you could supply me with? I’ll be more than happy to grab you the parts. Just don’t want to leave anything behind Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 17, 2022 Share Posted June 17, 2022 I really should take a pic of the entire set up out of the vehicle to aid in this type of situation. Anywhooo a fun short read for ya Should have everything there that needs to be yanked with pics of each part. The wiring harness should have a few things plugged into it which should help aid in what needs to go with the set up. Link to comment Share on other sites More sharing options...
