Ollie Posted May 23, 2022 Share Posted May 23, 2022 I have a 1989 4.0 stock cooling system. My electric fan is not coming on. Is there a temp sensor that controls this fan, if so where is it? Is it wired thru the AC system? I know the fan is good because I have tested it straight to the battery. Ollie Link to comment Share on other sites More sharing options...
87MJTIM Posted May 23, 2022 Share Posted May 23, 2022 The temperature sensor screws into the radiator- driver’s side, next to the e-fan. The temperature sensor triggers a relay that powers the fan. The relay is on the driver’s side inner fender. Try removing the relay and jump the power supply. If the fan comes on, then it maybe the sensor is bad. Link to comment Share on other sites More sharing options...
Ollie Posted May 23, 2022 Author Share Posted May 23, 2022 Issue solved !!!!!!!! The temp sensor was unplugged. Fan now comes on when AC is engaged. Thanks a million Ollie Link to comment Share on other sites More sharing options...
