what is the rear driveshaft length for a shortbed, automatic (AW4) 4.0 MJ?
then, Smitte, can you measure your rear driveshaft. I'm not sure how to measure shaft length so hopefully someone here will tell us how.
EDIT:
this is a 4wd equipped truck (or will be when I'm done)
when i measured for my solid axle nissan it had a slip yoke i measured from the output of the tcase to the back of the yoke on the axle. driveshaft shop did the rest.
i used string to get it dead on.
