JD1 Posted April 30, 2022 Share Posted April 30, 2022 I want to know if anyone knows where I might find the clip that secures the top part of the armrest/pull to the door itself. It is attached to the door. Link to comment Share on other sites More sharing options...
Dandxj Posted February 22, 2023 Share Posted February 22, 2023 Did you ever find a source for the clip which snaps into the door? I also need one as one of mine has broken. Currently none of the local JYs have any 96 and down XJs ( or MJs). Has anyone else had this issue and found a clever fix? Link to comment Share on other sites More sharing options...
schardein Posted February 22, 2023 Share Posted February 22, 2023 I've pulled a couple from junkyard XJs before. They can be surprisingly hard to get out of the door intact. I don't currently have any. I could probably get some in the next couple weeks though. Link to comment Share on other sites More sharing options...
Dandxj Posted February 22, 2023 Share Posted February 22, 2023 If you do happen to come across some I would be interested in buying a couple from you. I will continue to look locally, if I find some I will let you know so you are not hunting for nothing. Thanks Link to comment Share on other sites More sharing options...
