Load sensing valves, U-bolt plates, extended shackles, RE sway bar links - WA
Airborne Janitor
Excellent condition brake load sensing valve. Complete with connecting arm and Dana 35 bracket. $125 shipped. SOLD
OK condition brake load sensing valve. Missing connecting arm. Includes Dana 44 bracket. $60 $40 shipped SOLD
Rear axle leaf spring U-bolt plates with shock mounts and hardware. $125 $90 shipped. SOLD
Rear axle leaf spring U-bolt plates with shock mounts cut off. $50 $35 shipped.
Extended shackles for MJ/XJ. Brand unknown. $35 shipped.  SOLD
RE1145 extended sway bar links. Brand new in packaging. $25 $20 shipped.
I take paypal, venmo, crypto, check or cash. Thanks.
  • Airborne Janitor changed the title to Load sensing valves, U-bolt plates, extended shackles, RE sway bar links - WA
  • 3 months later...
Hi !
    Really all I need is the Dana 44 differential cover bracket if you would consider selling the bracket separate?
I swapped my Dana 35 for a Dana 44 and was planning to reuse my valve.
Archived
