Airborne Janitor Posted March 19, 2022 Share Posted March 19, 2022 Is it possible to "bench test" a renix gauge cluster? I'm really concerned with the tachometer. I did a full cluster swap in my MJ and the tach "sticks", it sort of works, sort of doesn't. I'd like to be able to test the cluster I just picked up from the junkyard before swapping it. Thanks. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 19, 2022 Share Posted March 19, 2022 What year is the tach? It can be tested, you need ground, power and a wire lead to the coil or the tach signal from the diag port. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted March 19, 2022 Author Share Posted March 19, 2022 I want to say the junkyard tach is either an 88 or 89. It's renix for sure, manual speedo cable and it's blue. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 19, 2022 Share Posted March 19, 2022 Blue faces or the black “sport” style? Ok that doesn’t really matter but you should still be able to test it. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted March 19, 2022 Author Share Posted March 19, 2022 2 hours ago, eaglescout526 said: Blue faces or the black “sport” style? Ok that doesn’t really matter but you should still be able to test it. Black sport style. Is there a wiring diagram of sorts showing how to test it? Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 19, 2022 Share Posted March 19, 2022 Ummmmm there might be a wiring diagram that I can find right quick. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 19, 2022 Share Posted March 19, 2022 From the 88 XJ electrical manual. Link to comment Share on other sites More sharing options...
Airborne Janitor Posted March 21, 2022 Author Share Posted March 21, 2022 You reminded me that I actually have the 89 FSM. I was able to dig up the correct wiring diagrams and test the junkyard tach from the diagnostic port. Unfortunately it didnt work. Link to comment Share on other sites More sharing options...
