702_MJ Posted November 24, 2007 Posted November 24, 2007 Ok here's the deal, i got a headliner from a salvage yard that was in ok shape for a fixer upper. Its really fragile, the yellow stuff on the back is separating from the material on the front around the edges. My friend said that the best idea is to fiberglass the back and wrap the glass around the front edges about 6inches on each side. I think it will work, but any suggestions or comments about the idea will be appreciated. Thanks
JeepcoMJ Posted November 24, 2007 Posted November 24, 2007 That's what I do, except I fiberglass the entire thing, or at least resin the front. you will need to buy new material, and peel the old stuff off. otherwise you will stain the old stuff and it'll look like crap. ebay has headliner material
