NickMJ88 Posted January 9, 2022 Share Posted January 9, 2022 There are two bolts that come from the body that the accelerator pedal bracket slides onto to stay seated in place and they have both broke and now the pedal is just free floating around. The bolts are coming from the body so is there is a way to somehow fix this? Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 9, 2022 Share Posted January 9, 2022 Drill them out and install couple bolts. Weld on new bolts. Use a hand throttle. Link to comment Share on other sites More sharing options...
howeitsdone Posted January 9, 2022 Share Posted January 9, 2022 Did the nuts come off or the studs break? And how would they break?... But yeah, if studs broke then cut 'em off and weld on new ones or as mini said cut, drill, and bolt it in. (You'll need a 2nd person or some ingenuity like taping the head of the bolt...) Link to comment Share on other sites More sharing options...
