Might just kick myself in the head.....
The bolt pattern is a 5" circle that is the centered on the axle or hub(2.5"radius). You will only be moving the studs out 1/4" on each side. Just center the new holes in between the original holes.
Thanks I'm going to measure it tomorrow and see what I have left for material.
I hope that works out.. I'm going to catch hell pressing the old studs out, might have to just cut them off. IDK....might as well just make the dam^ adapters....... I like the brainstorming going on though!! :cheers:
A brass punch and a BFH makes the studs pop right out without damage.
The hardest part will be locating and drilling the new holes in the correct spot and making them the right size for the studs.
yeah I could draw it out on autocad and print it to make a template
think I should tack the studs on the back?
Just drill the hole thr right suze and a tack won't be needed.
