1J7FT26L8KL512098
89ComancheKid
1989 Jeep Comanche Sportruck
4.0L, AW4, NP242,  Dana 30 front, Dana 35c rear, SWB
Build date is unreadable
Central IL
Converted to 4x4. Engine is a little rough, but still runs okay and drives well. Only rust is on the rocker panels.
Picked it up in 2017 with 70k miles. Had to replace the cylinder head and head gasket because it had been overheated by a previous owner. Put the Dana 30 from a TJ under it in 2019, and put the AW4 and NP242 from an 89 XJ under it this year. Added a 2"front spring spacer to level it and make room for larger tires.
Original brown and tan Sportruck livery. "New" front DS fender due to previous owner hitting a tree or something. Original maroon carpet and interior with vinyl and cloth bench seat. Original AM/FM radio and door speakers. Replaced original original rally wheels with 16" aluminum wheels from a YJ with 31x10.50 A/Ts.
*D1 TRIM STYLE D1 - CLOTH BENCH
-H9
154 Zone 54-St Louis
1AA U.S. Dealer Retail
5AL Low Series Tracking
APA Monotone Paint
BAY 105 Amp Alternator
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHT Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JKB
K3Z STRIPE/BADGE/MOLDING/COLOR
KDC
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PE8
QE8
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
SCB Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TAD HIGHWAY TREAD
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z59 Left Front Spring Group Ix
Z78 Right Front Spring Group VIII
Build date 1/12/89
Body code TL61
Sold by ROYAL PARKWAY DODGE INC, SPRINGFIELD IL
