a.e. Posted September 26, 2021 Posted September 26, 2021 1991 Jeep Comanche 4.0/aw4/np231/dana30/dana44/longbed Build date: unsure North Pole Alaska Truck has 120k miles needs a new trans as the previous owner melted the tranny lines with a "custom" exhaust. Truck has a Mopar "snoway" plow installed by the dealer
eaglescout526 Posted September 30, 2021 Posted September 30, 2021 *C1 TRIM STYLE C1 - CLOTH &&&& VINYL BENCH SEAT -Y6 DARK SAND 172 Zone 72-Portland 1AA U.S. Dealer Retail 3VQ Customer Preferred Discount 4HA Special Scheduling Condition I ALA ALK APA Monotone Paint BAP 75 Amp Alternator BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KWW ST-DCL WHT "STLT R/T" LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RA8 Delete Radio SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 11/12/90 Body code JL62 Sold by GENE'S JEEP-EAGLE INC, FAIRBANKS AK HAHAHAHAHA. I love the giant Mopar Logo right in the middle of that plow. Thats hilarious.
