Posted (edited)
1987 Jeep Comanche short bed converted to truggy with 1.75" DOM tube back half, 112" wheel base
Manufacturing date unknown, sticker painted over and not legible
4.0L six cylinder, Advance Adapters Atlas 2 transfer case with 4.3 gear ratio.
Late 1970's Ford 3/4 ton axle set Dana 60 rear and Dana 44 front, 4.88 gears. RCV CV axle shafts in front axle. Rear axle has Eaton Detroit locker front axle has Eaton E-Locker4.
ATX slab bead lock wheels with BFG Baja KR3 40" red label tires
Power tank bottle mount on rear tool box.
Derale transmission cooler on rear toolbox
K Suspension triple radiator fan setup with switched third fan
Front end doved
Warn Zeon 8S winch
M.O.R.E. (Mountain offroad) stubby front bumper
Napier hood vents
Leigh performance machine (strokedjeep.com) 60mm throttle body four hole fuel injectors
PSC full hydro steering
Reid Racing front knuckles
Four link control arms front and rear.
Rock Hard 4x4 interior roll cage
KC Hilites DOT approved head lights, fender well LED rock lights
In use as extreme rock crawler and located at Santa Fe New Mexico USA
Edited by Seawheels
Update
Body: JM61
Build date: 2/27/87
Selling Dealer:  BROADWAY DODGE INC
Littleton, CO
*X8 Cloth Low-Back Bucket Seats -H9 DESCRIPTION NOT AVAILABLE ADL Skid Plate Group
AGJ Driver Assistance Group APA Monotone Paint AWE
BCQ Maintenance Free Battery CAC Low Back Bucket Seats CGW
CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DDQ 5-Speed Manual Transmission
DMR 3.55 Rear Axle Ratio DSA Anti-Spin Differential Rear Axle ERB 4.0L I6 MPI Engine
GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window
GPB mirrors HCC Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes
JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter LAP Shift Indicator Warning Lamp LMA Halogen Headlamps
MBF Bright Rear Bumper MDA Front License Plate Bracket MFD Bright Grille
NAF High Altitude Emissions NMB Standard Duty Engine Cooling PXB
QXB   RAB AM/FM Radio SBA Power Steering
SCE Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire
TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels XEA Tow Hooks
