Aussiemj Posted July 27, 2021 Share Posted July 27, 2021 Hi guys The previous owner has change the front dif to a solid diff (remove select trac)but has left the piping to the transfer case. Can I remove this plumbing. What problem will I have. What else should I do. Thanks Link to comment Share on other sites More sharing options...
watchamakalit Posted July 27, 2021 Share Posted July 27, 2021 If you want to remove it you can but I believe you will have to plug a vacuum line going to the tcase. Otherwise you will havve a vacuum leak. Link to comment Share on other sites More sharing options...
