schardein Posted June 18, 2021 Share Posted June 18, 2021 Original MJ full console top, called a "cover, shift" in the parts manual. I need to clear up space, so this is up for grabs. Details- this is the full cover with the original parking brake lever block off in place. Includes 4 mounting screws. Mounting points are good. The coin tray is ok, has one small hardly noticeable cig burn, and is a separate part that unbolts. The bad is the pocket at the front has what appears to be white paint in it, and the surface is misshapen, like it was slightly melted. The parking brake well has rust stains. I've scrubbed it pretty good, so it's about as clean as it's going to get with soap and water. So I am thinking $18 plus shipping for the whole thing. Or if you just want the parking brake cover piece, coin tray and screws, $18 plus shipping. I know the parking brake block off cover 3d print reproductions are available at $18, so I figure an original must be worth at least that much. Link to comment Share on other sites More sharing options...
schardein Posted June 25, 2021 Author Share Posted June 25, 2021 Console top is gone. Parking brake lever delete plate and coin tray available. Link to comment Share on other sites More sharing options...
scaleless Posted June 25, 2021 Share Posted June 25, 2021 I'll take the delete plate. PM sent. I'll I'll take the delete plate. Link to comment Share on other sites More sharing options...
schardein Posted July 9, 2021 Author Share Posted July 9, 2021 The block off plate and console top are gone. Still have the coin tray if someone can use that. It was a separate piece on the early consoles, but molded as one piece with the console top in later models. Link to comment Share on other sites More sharing options...
Archived
