Not Posted May 26, 2021 Share Posted May 26, 2021 SOLD 1989 Jeep Comanche 4WD automatic 4.0 L, 6-cylinder 121,500 miles Fuel injected throttle body Dana 30 front w/ factory command trac locker Dana 44 rear w/ limited slip 3.73 ratio 4 wheel disc brakes Also see: https://comancheclub.com/topic/64913-1j7ft26e1kl474909 PM me if you need more info or pics $12.500 New within the last 2000 miles: Driveshaft and driveshaft yoke Front axle pinion seal Rear axle pinion seal Starter (4) Rancho shocks Complete distributor Fuel pump Fuel line from tank to engine Ignition coil Ignition control module Complete exhaust Fuel pressure regulator Coolant temperature sensor Cam crank position sensor Front wheel bearings Steering box Power steering pump and reservoir Steering stabilizer shock Spark plugs and wires Battery and cables All LED lighting in and out except for brake/turn lights (USED) electronic control module (USED) transfer case Repaired fuel sending unit on gas tank Repaired head, brake, and turn lights wiring Link to comment Share on other sites More sharing options...
scaleless Posted May 26, 2021 Share Posted May 26, 2021 That's a pretty neat tire mount! Got any close-up pictures of that? Link to comment Share on other sites More sharing options...
Coyote Posted May 30, 2021 Share Posted May 30, 2021 On 5/26/2021 at 3:15 PM, scaleless said: That's a pretty neat tire mount! Got any close-up pictures of that? Thinking the same thing. Prefabbed or homebuilt from scratch? Pics would be awesome. Link to comment Share on other sites More sharing options...
Not Posted May 31, 2021 Author Share Posted May 31, 2021 On 5/26/2021 at 3:15 PM, scaleless said: That's a pretty neat tire mount! Got any close-up pictures of that? On 5/30/2021 at 1:30 PM, Coyote said: Thinking the same thing. Prefabbed or homebuilt from scratch? Pics would be awesome. It's part of the custom roll bar that one of the previous owners installed and/or fabricated. I agree it's a neat look, but less neat when you're trying to load the bed full haha. Original quality pictures here: https://photos.app.goo.gl/KWvDLUyrSFeC484u7 Link to comment Share on other sites More sharing options...
scaleless Posted May 31, 2021 Share Posted May 31, 2021 Neat! I could understand about the bed haha. Thanks for sharing the pics! Link to comment Share on other sites More sharing options...
Coyote Posted May 31, 2021 Share Posted May 31, 2021 Nice! Thanks for the pics. Link to comment Share on other sites More sharing options...
Archived
