Fernando87mj Posted May 18, 2021 Share Posted May 18, 2021 Well I picked up another project since I really needed another one It’s a 1983 Datsun 280zx , had been wanting one for a while and when I saw this one I knew I had to have it. it’s sat for 11 years but the body is really clean and mostly rust free. Here’s some pics of when I picked it up. so far only things I’ve done do it is.. -drained old gas from tank - re installed valve rocker that fell off due to I’m guessing sticking valves. -Painted valve cover and installed new valve cover gasket -found why I was running on 4 cylinders (bad spark plug wires) -found why I had no turn signals (bad hazard switch ) - found why I don’t have brake lights (broken brake pedal switch stopper) - replaced fuel filter - replaced fuel pump -replaced fuel line from tank and deleted fuel damper valve Rocker/retained that had fallen off old gas wasn’t helping with the sticking valves Gold = horsepower Link to comment Share on other sites More sharing options...
pizzaman09 Posted December 26, 2021 Share Posted December 26, 2021 Wow, that's quite a project, definitely in need of some love. A friend of mine brought a similar 280zx to autocross. It was completely original and hadn't really been driven in many years. It had more power than I was expecting, clearly designed to be a cruiser. Link to comment Share on other sites More sharing options...
