High Idle Speed
I know that this has been discussed numerous times before, and I
have tried to read all of the posts on this that I could find. I have a
'87, 4 litre, 5 speed. I cannot get it to idle properly. I have checked
all of the vacuum lines for leaks. Everything seems sound. I have changed the map sensor, cleaned the throttle body, even changed throttle bodies. Have checked the TPS. 4.98 volts at the harness connector.
TPS is set at .82 volts at closed throttle. Will increase in voltage to 4.96
volts at WOT. When I start the vehicle...3000 rpm. Occacionally it will
idle properly when it is cold. Once it warms up... 2500 -3000 rpm.
Sometimes, I can punch the accelerator and the rpm's will drop.
Any ideas??
Jeephack
Try cleaning the idle air controller.
Also, consider the throttle linkage. Yeah, I know -- it's a cable. Well, actually it's a cable that connects to a linkage. Stand on the driver's side of the engine bay and look down between the block and the inner fender. Below the exhaust manifold there's a bellcrank. Twice with my '88 XJ I have had to liberally spritz that bit of linkage with penetrating oil to free it up and cure a sticking throttle.
Just a quick update and many thanks to Eagle for pointing an old dog
back to simple basics. Though the throttle cable in the engine compartment was fine, once I traced it back into the cab and under the dashboard, I found that one of the electrical harnesses had migrated
south and was lying across the cable preventing it from fully retracting.
Once the wayward harness was relocated, the truck idles just fine. :D
Thanks again,
Jeephack
Well---not being one to let well enough alone for very long, I have
created another problem that maybe you guys can help me with.
Been reading about bored out throttle bodies, and since I had a spare
one lying around, I thought I'd give it a try. Bored it out to 60mm.
Cut a new throttle plate. (16 ga. polished stainless!) Everything went
back together fine. Bolted it on the 'Manche and now it idles at around
3000 rpm. Are there adjustments that have to be made for the larger
throttle body opening? I must make this thing work!! It sounds and feels
awesome when you punch the throttle!!!
Jeephack
