LiamTuck Posted February 5, 2021 Share Posted February 5, 2021 Just got a 1986 COMANCHE XLS 2.8L THE TURN SIGNALS AND WIPERS DON'T WORK. I HAD THE WIPERS GOING FOR AWHILE BUT NOW THEY ARE BAD AGAIN. THE TURN SIGNALS DO NOT WORK AT ALL. THE HAZARDS WORK GREAT. I HAVE REPLACED THE FLASHER S AND THE SWITCH IN THE STEERING WHEEL. CHECKED ALL FUSES ETC. NOTHING. ALSO THE BLOWER MOTOR WASNT WORKING UNTIL I TOOK THE FUSE OUT THEN IN THEN OUT THEN IN. WORKED GREAT BUT NOW THE FUSE IS LOOSE SO IF I PUSH THE FUSE DOWN IT WORKS BUT DOESN'T WORK OTHERWISE. PLEASE HELP. I REALLY WANT TO GET THIS TURCK ON THE ROAD. I LOVE IT! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 5, 2021 Share Posted February 5, 2021 Pull all your turn and tail light bulbs and carefully inspect the bulbs and sockets. This is a very frequent issue and you will find several tips in the diy section. You’ll also find tips regarding the pre HO (91) model MJs under @cruiser54’s signature. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 5, 2021 Share Posted February 5, 2021 Here is a link to that thread: https://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ Link to comment Share on other sites More sharing options...
