zomeizter Posted April 3, 2021 Author Share Posted April 3, 2021 Took the truck for a drive to break things in and to check on road behavior, all is well, even the shackle angle improved! Link to comment Share on other sites More sharing options...
Pete M Posted April 3, 2021 Share Posted April 3, 2021 excellent! don't forget to check all your torque values. "some settling may occur" Link to comment Share on other sites More sharing options...
zomeizter Posted April 12, 2021 Author Share Posted April 12, 2021 On 4/3/2021 at 12:05 AM, Pete M said: excellent! don't forget to check all your torque values. "some settling may occur" Fo shizzzle. Link to comment Share on other sites More sharing options...
zomeizter Posted July 2, 2021 Author Share Posted July 2, 2021 Got some rubbing going on with the tie rod and quick disco bottom, does this mandate a dropped pitman installation? Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2021 Share Posted July 2, 2021 the rule of thumb is that drop pitmans should only be used if you're also dropping the trackbar mount too. otherwise it screws up the angles and brings bump-steer into the equation. I know I've seen some sort of relocation brackets for the lower sway links, but can't think of the company at the moment because my google results are flooded with JK and JL relocation brackets. Link to comment Share on other sites More sharing options...
Pete M Posted July 2, 2021 Share Posted July 2, 2021 found a tiny picture: Link to comment Share on other sites More sharing options...
zomeizter Posted July 5, 2021 Author Share Posted July 5, 2021 Hell yes, thanks Pete, Chupacabra drives really nice as is and I would not want to alter handling at all. On the lookout for some relo bracketry...or I may just fab something off my hording stash. Link to comment Share on other sites More sharing options...
