wilto Posted January 24, 2021 Posted January 24, 2021 Hey all, There is a significant leak coming from the master cylinder where it comes through the firewall, directly over the fuse box. I'm looking to keep my Peugeot transmission for now (until I can afford an upgrade). For the time being, what do you guys recommend for replacing/upgrading the master cylinder? On the forums I see all sorts of varying responses on what master cylinder to get (Luks, Doorman, etc). I've also seen some say to replace both the master and the slave? What has worked for you? I just need something that won't be too expensive and won't be too much of a bear to fix. Also my fuse box pretty much looks toast at this point, should I try and replace all the recessed/missing pins, or just get a new one from ebay/junk yard? Thanks!
wilto Posted January 24, 2021 Author Posted January 24, 2021 Found this one that's closest to me: https://www.napaonline.com/en/p/NCF72205?partTypeName=Clutch+Master+Cylinder&impressionRank=1&keywordInput=clutch+master+cylinder
jeepsouth Posted January 24, 2021 Posted January 24, 2021 That one looks just like the one i got at o'rielys about four years ago. It's working great.
