Joe Doviak Posted January 11, 2021 Share Posted January 11, 2021 Hey guys just upgraded to four port Volvo fuel injectors. She fired right up for a quick test. I reinstalled the air box and buttoned down the rail and crank no start. No pressure at the fuel rail shrader valve after priming ignition to On but if I disconnect the inlet to the regulator before the rail I have plenty of pressure. There are 2 orange washers with a black spacer between them on the male fuel input. (That I keep dropping everytime I disconnect this thing to troubleshoot haha) Is there a way I can test or replace just the regulator? Don't think an o ring could be juping out and clogging the port.. (see close up pic)I'm in Hawaii so parts are severely limited here. Aloha! Update: Removed pressure regulator but it's pressed together. Can I hit this with a carb cleaner or will that disintegrate the diaphram? Link to comment Share on other sites More sharing options...
Joe Doviak Posted January 11, 2021 Author Share Posted January 11, 2021 Link to comment Share on other sites More sharing options...
Big Dan Posted January 12, 2021 Share Posted January 12, 2021 I would assume it would deteriorate the o rings.The o ring in your last picture is a regular injector o ring, if I remember correctly.The o rings inside of the regulator can be replaced. If someone else doesn't chime in with the part number, I'll look it up. Sent from my Pixel 4 XL using Tapatalk Link to comment Share on other sites More sharing options...
Joe Doviak Posted January 12, 2021 Author Share Posted January 12, 2021 Thanks Big Dan. I replaced the pressure regulator but still have the same problem. Gonna remove the rail tomorrow.. all I can think of is a blockage in the rail.. Hoping I find some poor bastid's 10mm socket or something. Will update with my findings.. Link to comment Share on other sites More sharing options...
